Hi,
This is a followup to another thread:
https://forum.videohelp.com/threads/355146-%5Brtmpdump%5D-Download-rolls-back-stores-th...-several-times
The issue I had with the download restarting could be resolved by adding either the --live or --realtime flag to the command, and I can now get a file that includes the full length of the video. The resulting file seems to work fine during approximately the first 70 seconds (consistent over many retries). After that, the audio keeps working well, but the picture basically turns into a sequence of still images, updated about once per second. It looks a bit like a slide show of a photo sequence.
So, again, I'm trying to download this video:
https://www.ipam.ucla.edu/wowzavideo...p4&vfd=gss2012
...and here's a short video sample of the result:
https://mega.co.nz/#!FJli3TbJ!GsUe9g...PW2t0rTQkv9q7s
(The problem starts around 1:10.)
I'm on Linux Mint 13, using the git repository version of rtmpdump from the 10th of April 2013 (compiled statically).
The first minute of a run would look something like this:
I have only clocked the data transfer rate this once, but it seems typical, and as you can see it evaluates to about 30 kB/s. My ISP is providing a symmetric 10 Mbps connection and I would assume that UCLA has plenty of capacity at their end. I'm located in Europe.Code:~/rtmpdump $ ./rtmpdump -e --realtime -l 0 -r "rtmp://128.97.46.13:1935/gss2012/" -a "gss2012/" -f "LNX 11,0,1,152" -W "https://www.ipam.ucla.edu/videoplayer/jwplayer.flash.swf" -p "https://www.ipam.ucla.edu/wowzavideo.aspx?vfn=10660.mp4&vfd=gss2012" -y "mp4:10660.mp4" -o mp4_10660.flv RTMPDump v2.4 (c) 2010 Andrej Stepanchuk, Howard Chu, The Flvstreamer Team; license: GPL Connecting ... INFO: Connected... Starting download at: 0.000 kB in approximately realtime (disabled BUFX speedup hack) INFO: Metadata: INFO: trackinfo: INFO: timescale 30000.00 INFO: length 98732634.00 INFO: language eng INFO: sampledescription: INFO: sampletype avc1 INFO: timescale 48000.00 INFO: length 157974528.00 INFO: language eng INFO: sampledescription: INFO: sampletype mp4a INFO: audiochannels 2.00 INFO: audiosamplerate 48000.00 INFO: videoframerate 29.97 INFO: aacaot 2.00 INFO: avclevel 40.00 INFO: avcprofile 100.00 INFO: audiocodecid mp4a INFO: videocodecid avc1 INFO: width 1920.00 INFO: height 1080.00 INFO: frameWidth 1920.00 INFO: frameHeight 1080.00 INFO: displayWidth 1920.00 INFO: displayHeight 1080.00 INFO: framerate 29.97 INFO: moovposition 32.00 INFO: duration 3291.14 1649.603 kB / 10.81 sec (0.3%)
Some search engine work seems to suggest that the server could have a more or less fixed rate for outputting the video and this low transfer rate isn't coping with that, so frames get dropped to stay in sync. That's just my best guess so far though, and I don't have much experience with theses issues.
Could you tell me the cause of this problem and if there's something I can do to fix it?
			Closed Thread
	No. Continue in same thread. https://forum.videohelp.com/threads/355146-%5Brtmpdump%5D-Download-rolls-back-stores-th...-several-times
  Can someone help? rtmpdumpBy RateD in forum Video Streaming DownloadingReplies: 3Last Post: 19th Aug 2012, 21:13
  RTMPDUMP to download BBC video from outside the UKBy vor12 in forum Video Streaming DownloadingReplies: 16Last Post: 11th May 2012, 14:40
  How to get Brightcove video with rtmpdump or rtmpexplorerBy Nedo72 in forum Video Streaming DownloadingReplies: 2Last Post: 7th May 2012, 15:09
  Second Grade Video Yearbook Turns Out To Be A Porn DVDBy zzyzzx in forum Off topicReplies: 2Last Post: 27th May 2010, 19:36
  cinvert .avi file in .png images sequenceBy robs05 in forum LinuxReplies: 4Last Post: 5th Oct 2009, 05:30
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
